WTH does the side bar button for the Overview Dashboard disappear when I change a user setting to default to another dashboard?
Try this: Go change your default dashboard to anything other than the Overview dashboard. The sidebar button for the Overview dashboard disappears and can not be brought back!
change the dashboard back to the default dashboard and it will appear again.
If you need to access the default dashboard with a separate dashboard selected as the default. Go to
Settings → Dashboards → click “open” next to Overview.
@petro I certainly know that. My point is that the GUI should work just as with any other dashboard with the same pop up providing the choice to show it or not…
Yeah, I really don’t understand the reasoning behind removing the Overview dashbaord from the sidebar once another dashboard is set as default. I’d like to be able to have a custom dashboard set as default, but be able to quickly access the Overview dashbaord when I need it. By removing the Overview dashbaord from the side bar, I have to make four taps, Menu > Settings > Dashbaords > Overview, rather than half that by keeping the Overview dashboard in the side bar, Menu > Overview.
