WTH doesn't the Alexa integration use the same UI as HA Cloud for entity config?
When using alexa trough the HA Cloud it is possible to configure the include/exclude entities from the UI. This is not available when using the Alexa component directly.
The same UI should be available for both, since they have the same configuration.
When you say “Alexa component directly”, are you referring to the Alexa Smart Home Skill?
Yes, forgot to mention that.
I know this is a ‘temporary solution’, but you can configure this from yaml.
Yeah, its what I’ve been using. But it would be great to use the UI for that, instead.
