WTH don't I get notifications about available updates?
@tom_l - I don’t think there was any restart involved. This was for the update yesterday from core 7.1 to 7.2, and nothing fired. I understand what you mean though, so it may be that I didn’t notice or something.
I’ve now updated, so I’ll keep an eye on it for next time as you say and look to do something on restarts. I have an automation already that runs on restarts, so can look to just add it to that perhaps if I can localise the conditions (or a parallel specific automation if not).
You should have restarted after adding the sensors. Also reloading automations (if that is what you did instead of restarting) will have the same issue.
I meant that there was no restart coinciding with the new core update arriving (there was of course one after it installed). The sensors have been in place and functional for a while now, so all should have (to my mind) been fully available to trigger for yesterday’s update from 7.1 to 7.2.
Anyway I’ll add the conditional check on HA start-up anyway, and keep an eye on it for next time there’s a core update to see if it notifies or not.
Sorry I thought you only implemented this 17 hours ago (time of your post) where as the .2 release was before that (2 days ago).
No probs - my fault for not being clear.
The implementation is fairly new (sometime last week), but was a little surprised it didn’t fire off when 7.2 dropped.
I’ll add your suggestion about the check on start-up anyway, and will keep an eye on it when 7.3 (or 8.0) drops.
@tom_l - To close this one off for my earlier issue/question, just got the ping for the 7.3 update correctly and successfully. So looks like your assessment for the 7.1 → 7.2 update notification failure was on the money.
It’s even ahead of the game, as the update isn’t actually available in the supervisor yet :wink:
Reload the supervisor on the system page then when it has restarted go to the supervisor dashboard and refresh the page.
No need - it’s here now and currently under install.
Hi, this card looks really nice. Would you maybe share your config?
Sure, I use a number of binary_sensors for the on/off warnings based on the underlying sensors, here’s the config - the card has changed a little bit since the original post but still basically the same:
entities:
  - type: custom:multiple-entity-row
    entity: binary_sensor.remote_ui
    state_color: true
  - entity: sensor.myip
    show_state: false
    icon: mdi:restart
    entities:
      - entity: sensor.last_boot
        format: relative
      - entity: sensor.ha_uptime
        format: total
    entity: sensor.database_size
    icon: mdi:database-outline
    state_color: true
  - type: divider
  - entity: binary_sensor.update_homeassistant
    show_state: false
    state_color: true
    name: Home Assistant Core
    tap_action:
      action: navigate
      navigation_path: /hassio/dashboard/
    entities:
      - entity: sensor.current_version
      - entity: binary_sensor.updater
        attribute: newest_version
  - entity: binary_sensor.update_os
    show_state: false
    state_color: true
    tap_action:
      action: navigate
    entities:
      - entity: sensor.os
        attribute: current_version
      - entity: sensor.os
  - entity: binary_sensor.update_supervisor
    show_state: false
    state_color: true
    tap_action:
      action: navigate
      navigation_path: /hassio/system/
    entities:
      - entity: sensor.supervisor
  - entity: binary_sensor.update_addons
    show_state: false
    state_color: true
    tap_action:
      action: navigate
    entities:
  - entity: binary_sensor.update_hacs
    show_state: false
    state_color: true
    tap_action:
      action: navigate
      navigation_path: /hacs/entry/
    entities:
      - entity: sensor.hacs
  - type: divider
    show_state: false
    secondary_info: last-changed
    icon: mdi:ip-network-outline
    entities:
      - entity: sensor.local_ip
state_color: true
title: Home Assistant
type: entities
Great, thank you! multiple-entity-row was the magical word :wink:
Btw, how do you get the Update notifications for the OS?
  - platform: command_line
    command: 'curl http://supervisor/os/info -H "Authorization: Bearer $(printenv SUPERVISOR_TOKEN)" | jq ''{"newest_version":.data.version_latest,"current_version":.data.version}'''
    value_template: "{{ value_json.newest_version }}"
    json_attributes:
      - newest_version
      - current_version
Then for consistency in Lovelace I use a binary_sensor to indicate if an OS update is available:
template:
  - binary_sensor:
      - name: Update OS
        state: "{{ state_attr('sensor.os', 'current_version') != state_attr('sensor.os', 'newest_version') }}"
        icon: "{{ 'mdi:information-outline' if states('binary_sensor.update_os') == 'on' else 'mdi:circle-outline' }}"
(moved to Update notifications! Core, HACS, Supervisor and Addons - #265 by e-raser)
