Home Assistant has its own Persistent Notifications. It would be great if information about available Home Assistant / Supervisor / Operating System updates was displayed in the notification drawer in web UI.
Don’t forget your own vote
There is a sensor for Home Assistant updates. It’s up to you to automate it. Not everyone may want alerts bugging them about this.
If you want a sensor that updates more than once a day:
sensors:
- platform: version
image: intel-nuc # change for your system, see https://www.home-assistant.io/integrations/version/
source: local
- platform: version
source: hassio
automation:
- alias: 'Update Available'
platform: template
value_template: "{{ states('sensor.latest_version') != states('sensor.installed_version') }}"
service: notify.telegram_system
data_template:
title: '*Information*'
message: "An update for Home Assistant is available. You are running {{states('sensor.installed_version') }}, the latest version is {{ states('sensor.latest_version') }}."
An OS update sensor would negate the need for adding this (so you get my vote):
sensors:
- platform: command_line
name: HassOS Installed Version
command: 'curl http://supervisor/host/info -H "Authorization: Bearer $(printenv SUPERVISOR_TOKEN)"|jq ''{"hassos":.data.operating_system}'''
value_template: "{{ value_json.hassos[7:] }}"
- platform: rest
resource: https://s3.amazonaws.com/hassio-version/stable.json
name: HassOS Latest Version
value_template: '{{ value_json.hassos["intel-nuc"] }}'
scan_interval: 3600
automation:
- alias: 'HassOS Update Available'
platform: template
value_template: "{{ states('sensor.hassos_installed_version') != states('sensor.hassos_latest_version') }}"
- service: notify.telegram_system
data_template:
message: "Update for HassOS available, from v{{ states('sensor.hassos_installed_version') }} to v{{ states('sensor.hassos_latest_version') }}"
Sensors for the supervisor aren’t needed as this updates automatically whether or not you think this is a good thing. However if you want it now (or this WTH does not get a PR):
sensors:
sensors:
supervisor_installed_version:
friendly_name: "Supervisor Installed Verion"
value_template: "{{ state_attr('sensor.supervisor_updates', 'current_version') }}"
supervisor_latest_version:
friendly_name: "Supervisor Latest Verion"
value_template: "{{ state_attr('sensor.supervisor_updates', 'newest_version') }}"
automation:
- alias: 'Supervisor Update Available'
platform: template
value_template: "{{ states('sensor.supervisor_installed_version') != states('sensor.supervisor_latest_version') }}"
data_template:
message: "Update for Supervisor available, from v{{ states('sensor.supervisor_installed_version') }} to v{{ states('sensor.supervisor_latest_version') }}"
Also, just for completeness:
HACS notification:
- alias: 'HACS Update Available'
platform: state
entity_id: sensor.hacs
condition:
condition: numeric_state
above: 0
data_template:
message: "Update for {{ state_attr('sensor.hacs','repositories')|map(attribute='display_name')|list|join(', ') }} available."
Addon notification:
- alias: 'Addon Update Available'
platform: state
entity_id: sensor.supervisor_updates
condition:
above: 0
data_template:
message: "{{ states('sensor.supervisor_updates') }} Addon update(s) available."
You can of course use automation for this. But in my opinion, this is standard functionality that should work out of the box. An automation platform should make our life easier, not complicate it, right?
For sure which is why I also said:
how do you create the sensor.supervisor_updates
Does this sensor also show the individual add-ons that have an update?
Sorry, I missed that one:
command: 'curl http://supervisor/supervisor/info -H "Authorization: Bearer $(printenv SUPERVISOR_TOKEN)"|jq ''{"newest_version":.data.version_latest,"current_version":.data.version,"addons":[.data.addons[]|select(.version != .installed)]}'''
value_template: "{{ value_json.addons|length }}"
json_attributes:
- newest_version
- current_version
- addons
haha, no worries
can I do this in Hassio OS too?
thinking of the authorization here especially.
using a rest sensor myself with authorization like this:
- platform: rest
name: Hassio Rpi4 config
resource: !secret resource_hassio_rpi4_config
value_template: > #components|list|count}}
{{value_json.version}}
json_attributes:
- components
- unit_system
- config_dir
headers:
Content-Type: application/json
Authorization: !secret api_bearer_token
User-Agent: Home Assistant REST sensor
scan_interval: 3600
could that be done for the supervisor sensor too maybe? Trying this:
- platform: rest
name: Hassio Supervisor Updates
resource: http://supervisor/supervisor/info
value_template: >
{{value_json.addons|length}}
json_attributes:
- newest_version
- current_version
- addons
headers:
scan_interval: 3600
without success yet. Is the url correct? in the Config Rest sensor I need to point to https://mydomain.duckdns.org:port/api/config
when I enter http://supervisor/supervisor/info this seems incorrect?
Maybe the version
platform can be modified to include an additional parameter to specify what info we want: Home Assistant, Supervisor, or Operating System.
WDYT?
Running on Home Assistant OS the following rest sensor works for me. The addons attribute gets fully populated.
platform: rest
resource: http://127.0.0.1:8123/api/hassio/supervisor/info
value_template: '{{ value_json.data.addons|count }}'
scan_interval: 1800 # 60 seconds * 30 minutes = 1/2 hour worth of seconds
headers:
Authorization: !secret rest_token
json_attributes_path: "$.data"
json_attributes:
- addons
Then a template sensor I call sensor.addon_updates
to count the number of addons with update_available
== True
. As a bonus this sensor also lists the
platform: template
sensors:
addon_updates:
friendly_name: Addon Updates
icon_template: mdi:counter
value_template: '{{ state_attr("sensor.addons","addons") | selectattr("update_available","eq",True) | map(attribute="name") | list | count }}'
attribute_templates:
addons: '{{ state_attr("sensor.addons","addons") | selectattr("update_available","eq",True) | map(attribute="name") | list }}'
Thanks for this, noticed that
Was slightly off and need pushing a few characters right to get the version number, so had a dig around and stumbled on this which serves up both current an latest version for the OS - however suspect this is constrained to the once a day update that you were trying to overcome!
command: 'curl http://supervisor/os/info -H "Authorization: Bearer $(printenv SUPERVISOR_TOKEN)" | jq ''{"newest_version":.data.version_latest,"current_version":.data.version}'''
value_template: "{{ value_json.newest_version }}"
json_attributes:
- newest_version
- current_version
Anyway, thanks for the post - helpful!
Got my dashboard nearly to my liking
I updated it here:
