WTH: Entity labels are truncated
When adding cards to the dashboard using the entity filter, the entity labels are being truncated due to arbitrarily small widths of the container.
In this example I have no idea which one is the one I want because they are all labeled the same due to arbitrary truncation. I appreciate all the electric energy ones have discrete, if similar, icons but why should I have to study which is which. Just show the whole label!
This is unlike the very similar way the entities are presented in automations/scrips, where it is also small widths but it’s totally fine because labels are not truncated.
I say truncating labels is almost always a bad move. I’ll be happy either way if they enable multiple lines or they give the container more width for better use of the vast amounts of available space.
click on the top bar to expand the configuration window.
Edit: Looks like that’s not available on that window… wth
Right lol That’s not applicable here. I know that works in some other places like the more info dialog and can be useful and also frustrating when trying to select text from the header.
Vote for your own WTH! :slight_smile:
Personally, I feel the current list-tree HA uses have an overly excessive indentation. It can be reduced significantly to prevent cases like this, even before widening the container or wrapping onto multiple lines.
Yeah, it’s really not easy to use and view and find labels in the UI. They are a great tool but the implementation seems to be to be optimized for
  • Short labels: apple, orange,pear but not dragon-fruit, watermelon
  • Max 2-3 (short) labels assigned to anything before the power of labels must be hidden
  • Only having about 20-30 labels overall…(searchable in the entity/device filter, but) not in the list where you assign them to something,
Maybe I’m in a minority in tagging everything with intersecting for more power and flexibility in scripts and automations.
I basically use labels like Venn Diagram Set Theory
