Hi everyone,
I’d like to suggest a new feature for Home Assistant that could improve system management and troubleshooting: Entity Relationship Mapping.
Idea:
Introduce a feature to visualize and/or list relationships between entities, automations, scripts, and other components within Home Assistant. This mapping could provide an intuitive way to understand how different parts of a setup are interconnected.
Key Features:
Visual Mapping:
- A graphical representation of relationships between entities and their triggers, dependencies, and linked automations/scripts.
- Example: a flowchart showing how a motion sensor triggers a light, which is controlled by a specific automation.
Entity Dependency Table:
- A detailed table listing entities, their triggers, and what they influence (e.g., which automations or scripts they are part of).
- Include options to filter by entity, integration, or automation.
Troubleshooting Assistance:
- Highlight broken or missing relationships (e.g., if an entity referenced in an automation is unavailable).
- Provide warnings or recommendations for fixing these issues.
Change Impact Analysis:
- When editing or removing an entity, show a list of automations, scripts, and dashboards that will be affected.
- Example: if you remove a temperature sensor, Home Assistant warns you about the automations that will break.
Integration with Dashboard:
- Allow users to add visual maps or dependency tables to dashboards for quick access.
Use Case Examples:
- Troubleshooting Automations: easily identify why an automation isn’t working by seeing if a key sensor or entity is unavailable.
- System Optimization: quickly spot unnecessary or duplicate dependencies between entities and automations.
- Complex Setups: for large systems with many integrations and automations, visualize how everything works together.
Benefits:
- Improves clarity and understanding of Home Assistant setups.
- Speeds up debugging and troubleshooting.
- Reduces the risk of breaking automations during changes or updates.
- Makes Home Assistant more beginner-friendly by providing insights into system behavior.
