e-raser
September 30, 2022, 9:16pm
1
…cause our (long-term) data is the basis of our smart homes!
My first very negative experience with HA back in the days: corrupted database.
Up to now they are still (almost) useless and a pain in the beep to fix (if possible at all).
Everything is said here:
In the end I only have one question :
Assuming those will finally fix this, what about
home-assistant:dev
← agners:ha-core-backup-notification
opened 09:58PM - 02 Dec 21 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N… OT DELETE ANY TEXT from this template! (unless instructed).
## Breaking change
If your PR contains a breaking change for existing users, it is important
to tell them what breaks, how to make it work again and why we did this.
This piece of text is published with the release notes, so it helps if you
write it towards our users, not us.
Note: Remove this section if this PR is NOT a breaking change.
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
This implements two new Websocket API endpoints `backup/start` and `backup/end`. Those are meant to notify the Core when the Supervisor is creating a backup of the Core. Since backups are done while the Core is running, this allows the Core to make sure all files in the `config` directory are in a safe state to read. Until now, the recorder continued to write to the database file while the backup is being made. This can lead to corrupted database files in the backup. With this implementation, the recorder locks the database using `BEGIN IMMEDIATE`, which essentially prevents writes from any Database connection while keeping the database available for reads. The implementation also halts the recorders queue so that no database inserts are even attempted.
This method is described as "historical" method in the SQLite documentation. Developers also confirmed that this method is still save to use and also works with WAL enabled.
https://www.sqlite.org/backup.html
https://sqlite.org/forum/forumpost/1307e369863b7b24?t=h
Note: Currently the `backup/start` and `backup/end` endpoints are implemented in the recorder directly. In case other components need to know when a backup is created, the Websocket API endpoint should be implemented as part of the `hassio` component or similar.
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [x] New feature (which adds functionality to an existing integration)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [ ] There is no commented out code in this PR.
- [ ] I have followed the [development checklist][dev-checklist]
- [ ] The code has been formatted using Black (`black --fast homeassistant tests`)
- [ ] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
The integration reached or maintains the following [Integration Quality Scale][quality-scale]:
The Integration Quality Scale scores an integration on the code quality
and user experience. Each level of the quality scale consists of a list
of requirements. We highly recommend getting your integration scored!
- [ ] No score or internal
- [ ] 🥈 Silver
- [ ] 🥇 Gold
- [ ] 🏆 Platinum
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[manifest-docs]: https://developers.home-assistant.io/docs/en/creating_integration_manifest.html
[quality-scale]: https://developers.home-assistant.io/docs/en/next/integration_quality_scale_index.html
[docs-repository]: https://github.com/home-assistant/home-assistant.io
and
home-assistant:dev
← home-assistant:recorder_refactor_queue_handling
opened 01:33PM - 07 Dec 21 UTC
## Proposed change
Refactor recorder queue handling to avoid multiple `isinstance` calls on each handled event
This address some concerns raised in review of https://github.com/home-assistant/core/pull/60874
## Type of change
- [ ] New feature (which adds functionality to an existing integration)
- [x] Code quality improvements to existing code or addition of tests
## Checklist
- [ ] The code change is tested and works locally.
- [ ] Local tests pass. **Your PR cannot be merged unless tests pass**
- [ ] 🥈 Silver
- [ ] 🥇 Gold
- [ ] 🏆 Platinum
been reviewed.
→ When will they finally arrive in a productive release? Or did they meanwhile, silently?
Since having long term statistics and building powerful things like the energy dashboard with it, people have something to loose when the database is corrupt. The old sentence “Just start from scratch!” (which is what happens automatically) is a slap in the face nowadays.
So I really would love to kick my additional paranoia step (if you’re gone trough 3 database restoration processes and care for your data, you will get paranoid automatically) run every now and then, usually before a monthly HA Core update:
ha core stop; cp /config/home-assistant_v2.db /backup/home-assistant_v2_BU_$(date +%F\_%H%M%S).db; ha core start
They were both merged 10 months ago… I guess if you’re not aware, if something is merged then it is included in next major release. So in this case that was 2022.2.0
(and obviously every release after that).
Sometimes commits are cherry picked into a patch release of the previous major version. One of those has the cherry picked tag so it actually came out even before 2022.2
, was in one of the patches of 2021.12
