WTH - Getting back to Home Dashboard from deep inside Settings with a single click
There is no way to get back to Home Dashboard when you are deep inside settings with a single click. You have to keep hitting the back button until you are home.
Suggestion: Long Pressing Back Button gets you to Home Dashboard where ever you are.
Click your dashboard icon in the left hand menu.
I use it with side bar hidden :frowning_face:
There’s your problem.
The sidebar is always there on a PC (if you have it showing). But in the mobile app the sidebar disappears as soon as you select a section from the Settings screen. At least it does on mine (Android).
If I head into the configuration of a device or entity, or edit an automation, and want to go back to the default dashboard, it seems the only way to get there is to hit “back” multiple times until the menu re-appears, then hit the hamburger icon to then select the dashboard.
As the main user interface, I would love for a persistent button, available everywhere, to jump straight back to the dashboard.
