We are regularly told that the forums aren’t where architectural or UI changes are debated, and to follow Discord or GitHub Discussions instead. I’ve tried doing exactly that to find the background on the recent 2026.11 entity naming changes, and I’m hitting a dead end:
Discord: I actively monitor the Projects and Developer channels, and I haven’t seen any discussion covering this change.
GitHub: In the GitHub mobile app, the main home-assistant/core repository doesn’t expose a Discussions tab—I only ever reach it when someone drops a direct link in the forums. Even when I do get to the Discussions page and scroll back through days of posts, nothing about the naming change stands out.
Could someone clarify where these decisions are actually discussed before release, and share a direct link or search path beyond a generic “check Discord and GitHub”?
You’re hitting a dead end with the naming changes because they started so long ago and the process was different then. The discussions for that are fractured all over the place. For future changes, the discussions happen in core projects in the developer channels. There’s a Projects channel in developers area that has each overarching project.
For all intents and purposes this post covers what you’re looking for:
I do not know where all the different discussions in that case where held, for that you would be better to read all the replies in the exisisting comments here as sure it have already been asked and answered here → Naming things in Home Assistant, shaped by your feedback
I hope though for future transparency links to all different official channels and discussion forums or respos should hopefully be linked via the new contributors subsection on the website here:
Anyway, changes like that will normally be created as an open architecture discussion before approved, and there you can join the discussion to give constructive feedback or ideas:
And once a large architecture change proposal or proposal for big new architecture is approved it should probably also be be entered in repo as an Architecture Decision Record (ADR) as well:
Tip if you want to try to keep up and follow what is going on then read all the issues tracked and discussions via various Open Home Foundation repos, like roadmap, goals,
