While Home Assistant seems to be using oAuth2 internally (I have not checked this), there is no way to delegate authentication to an external identity provider.
Also I do not have any clear understanding on why we do not want to do it .
home-assistant:dev
← elupus:openid
opened 10:13AM - 18 Mar 20 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N… OT DELETE ANY TEXT from this template! (unless instructed).
## Breaking change
If your PR contains a breaking change for existing users, it is important
to tell them what breaks, how to make it work again and why we did this.
This piece of text is published with the release notes, so it helps if you
write it towards our users, not us.
Note: Remove this section if this PR is NOT a breaking change.
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
Add support for using OAuth2/OpenId authentication providers like google, facebook
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [ ] New integration (thank you!)
- [X] New feature (which adds functionality to an existing integration)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Example entry for `configuration.yaml`:
Supplying a configuration snippet, makes it easier for a maintainer to test
your PR. Furthermore, for new integrations, it gives an impression of how
the configuration would look like.
Note: Remove this section if this PR does not have an example entry.
```yaml
# Example configuration.yaml for google openid provider
homeassistant:
auth_providers:
- type: openid
client_id: "1234"
client_secret: "4567"
configuration: https://accounts.google.com/.well-known/openid-configuration
emails:
- "[email protected] "
```yaml
# Example configuration.yaml for auth0 provider supporting a multitude of underlying providers
homeassistant:
auth_providers:
- type: openid
client_id: "1234"
configuration: https://xxx.auth0.com/.well-known/openid-configuration
emails:
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
This requires changes in frontend to work correctly with external flows.
Users are whitelisted based on their (verified) email address. That however does require the email scope of openid, which we don't really need. Also email is not really considered a "stable" identifier. That said, the link between a home assistant user and the "upstream" user is based "sub" (subject) identifer. So even if email where to change, we'd still keep the link to same home assistant user.
- This PR fixes or closes issue: fixes #
- This PR is related to issue: https://github.com/home-assistant/frontend/pull/5258
- Link to documentation pull request:
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [x] There is no commented out code in this PR.
- [x] I have followed the [development checklist][dev-checklist]
- [x] The code has been formatted using Black (`black --fast homeassistant tests`)
- [x] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [ ] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [ ] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [ ] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] Untested files have been added to `.coveragerc`.
The integration reached or maintains the following [Integration Quality Scale][quality-scale]:
The Integration Quality Scale scores an integration on the code quality
and user experience. Each level of the quality scale consists of a list
of requirements. We highly recommend getting your integration scored!
- [ ] No score or internal
- [ ] 🥈 Silver
- [ ] 🥇 Gold
- [ ] 🏆 Platinum
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[manifest-docs]: https://developers.home-assistant.io/docs/en/creating_integration_manifest.html
[quality-scale]: https://developers.home-assistant.io/docs/en/next/integration_quality_scale_index.html
[docs-repository]: https://github.com/home-assistant/home-assistant.io
It seems that it would be a while before it is implimented.
I am working on a guid to use Authentik with services that use JWT Authentication .
With HA it is a bit diffrent since they have implemented it difrently.
I am looking for a way to obtain Refresh Tokens and use them to bypass login. Sadly the Documentation is not super clear about it.
