WTH, if a Zwave paddle is pressed but the state isn't changed, HA doesn't know
If a light is already on, and you manually press that paddle switch again, there’s no signal sent or detected unless there’s actually a change in the light itself.
A tap of a button on an already on light could be used to disable an automation temporarily. We’ve found this to be a challenge when programming our ceiling fan switches.
This can also be useful for cases where a zwave light switch is used in conjunction with philips hue bulbs
Sounds like you’re referring to central scene support?
The current integrated Z-Wave implementation kinda support scenes, but it is not clear how.
Is this a WTH moment, yes… It should be more apparent how to do this and it should be easier to do!
Below is an example of triggering an automation from a Z-Wave Node Event for a scene controller.
automation:
  - alias: "HKZW-SCN04 Moon Button Press"
    mode: single
      - platform: event
        event_type: zwave.scene_activated
        event_data:
          entity_id: zwave.hank_hkzwscn04_scene_controller
          scene_id: 1
          scene_data: 0
      - service: light.turn_on
        entity_id: light.bedroom
  - alias: "Bedroom - HKZW-SCN04 People Button Press"
    mode: single
      - platform: event
        event_data:
          scene_id: 2
          scene_data: 0
      - service: switch.turn_on
        entity_id: switch.bedroom_fan
Now if you are talking about a Z-Wave wall switch (Jasco, GE, etc…), then the following can be used. The state of the switch doesn’t matter for these events. BUT, you MUST associate Group 1 for single tap and Group 2 for double tap to the Z-Wave controller (Node 1) so that the switch will send the events to the controller. You can also associate other Z-Wave devices to Group 1 and Group 2 to control them through Z-Wave network. I do this for lights/switches I want to be controller together and remove the need to HASS to have to process this automation, but if you want the same functionality if you turn on the light from HASS, you have to setup an automation because turning on the light/switch from HASS will not trigger the event associated with Group 1 or Group 2, but this can be device dependent…
automation:
  - alias: "Livingroom - Light Double Tap On"
    mode: single
      - platform: event
        event_type: zwave.node_event
        event_data:
          entity_id: zwave.livingroom_couch_lamps
          basic_level: 255
      # Turn on Livingroom and Kitchen lights with auto brightness
        entity_id:
          - light.livingroom_auto
          - light.kitchen_auto
      # Turn on TV
      - service: input_select.select_option
        entity_id: input_select.harmony
          option: 'Watch TV'
Hope this is helpful, this is how you can do this currently. All that being said, I will repeat myself, I agree with this WTH. It is a struggle to figure this out and did update the documentation, but the location of this documentation can be hard to find…
The latest iteration of openzwave has scene support out of the box, nothing to adjust or tweak.
