When you work on your Dashboard, it can be, that you have a lot of different cards within the vertical Stack-Card.
In this case, it sometimes is really a pain to do changes in the yaml or UI Editor, because you need to scroll down - to see your changes - but then, you need to scroll up again to do your changes.
The area for editing and preview should be splitted into two seperate areas - and the editor area should ALWAYS be visible, while scrolling will just have an effect on the preview area.
YAML Editor is tiny and small - I want to edit something on the bottom of my Stack card
so to see my changes - I need to scroll down
but then, my editor is gone - and I need to scroll up again to do the other changes.
