I want to right click on a trigger and choose to trigger it similar to how i can choise to run an action in the actions area. This is for testing purposes of the rest of the automation.
So, the trigger is âŚ
âsomething stateâ > 51
Whatcha gonna trigger for testing with a click? Didjya go to Developer Tools | State and set it?
What if the trigger is âŚ
trigger: state
entity_id:
- lock.back_door_lock
- lock.front_door_lock
- lock.basement_door_lock
to: unavailable
What does the âright clickâ do?
Or, if the triggers are:
triggers:
- trigger: state
entity_id:
- cover.big_garage_door
- cover.small_garage_door
for:
hours: 0
minutes: 0
seconds: 5
to: closed
- trigger: state
entity_id:
for:
hours: 0
minutes: 0
seconds: 5
to: open
- trigger: state
entity_id:
- input_boolean.notify_garage_open
to: "off"
What are you expecting the âright click triggerâ to do?
I think this may be a duplicate?
this is built in on a different page. use the set state feature in developer tools on a separate window and you can watch your automation trigger and then trace it⌠too many variables for a button, which is why you type it in in the dev tools.
