WTH is it so hard to make ESPHome devices that continue to work in wifi or power failures
This WTH has 3 different closely related complaints:
  1. Making ESPHome devices that still work when Home Assistant is down
  2. Making ESPHome devices that still work when the Wifi is unavailable
  3. Making ESPHome devices that maximize battery life well
I’ll use the concrete example of our ESP32 automated Cat Feeder for demonstration.
Specifically, for (1), it’s hard to write “fallback” cases that attempt to use home assistant for events etc, but if they fail continue to run successfully. (I still want the cat to be fed, even if HA can’t receive events, and I don’t want the ESP device to reboot trying to connect when HA is down)
For (2), it’s similarly difficulty, because ESP32 devices reboot constantly when their wifi connection fails, and it’s not obvious how to prevent it. (Again, I want the cat fed no matter what, even if the router dies)
Finally (3) is the worst issue, because if I have a battery backup, all the options to make deepsleep work on esp32 are very overwhelming and feel like they need a ton of research to get right, and if you’re wrong? Sorry it either fails entirely, or your battery is used immediately and dies very quickly.
I’d love to see additional guides for making more resiliant ESPHome devices, not just very varied ones.
ESPHome is not in the scope of WTH Month.
Moved to ESPHome.
For the first 2, I don’t see the problem. My setups are working without issues without HA or Wifi. The 3. one might be trickier, deep sleep usage could be handled better…
Recently my HA server went down for a few days and i had same problem so i started looking for ways to run some “critical” devices independently.
1- You can disable the reboot on api failure using reboot_timeout: 0s under api field. If your devices relies on comunicating with each other, you can use UDP component to broadcast actions and webserver for a web interface.
2- If you are using time based triggers(ex: cat feeder runs at 4pm every day) the ds1307 is an option paired with datetime component.
For the first 2 challenges
Api and wifi need a timeout set to 0
