WTH is not possible reload command_line yaml without restarting HA
If I change something in command_line section I must restart HA to changes take effect. Why?
Did you give your yam command line entities unique ids?
If so you should be able to use this:
Screenshot 2024-12-01 at 17-40-36 Developer tools – Home Assistant
Wow. I missed this. Thanks.
Please mark the post as a solution if you find it works and I’ll close the WTH to lighten the load on the devs sifting through them.
