WTH is the entity and device name field empty?
When renaming an entity or device from the default name, why is the name field empty, instead of being populated with the current name?
I often want to make small tweaks to the default name. In order to do that I need to copy and paste the existing name from the title of the dialogue box, or type the whole name in again.
While I understand this could help to see if the name has been updated from the default name, it makes the renaming process much more cumbersome, especially on mobile.
Thank you kindly for your consideration!
