When you are viewing a MAP and you are zoomed in or out, it will always reset the zoom to default on refresh of data. i.e. when the position of a person is updated it will zoom out again.
You can turn that off
Then maybe the WTH is really to add that to the visual config editor
Thank you, I used focus on the devicetracker entity and it worked.
I think that counts for a lot of things, that needs to be added to the UI.
I am not shy for YAML especially when copy and paste between cards/automations and stuff. But if Home Assistant wants to be more “normal” user friendly they need to do a lot of more UI based. But they heading the right direction, it is all about resources and time.
But I am happy for now.
Should have a fix for this next month
