Let’s say I have a list of rooms:
{% set my_list = ["Bedroom", "Dining Room", "Guest Bedroom", ...] %}
And I have a temperature and humidity sensor in each room and I want to get a list of temperature and humidity sensors for each room. Each of those sensor’s has an entity ID like this:
sensor.<room name slugified>_temperature
sensor.<room name slugified>_humidity
To do that, I need to use regex:
{{ my_list | map('slugify') | map('regex_replace', '^(.*)$', 'sensor.\\1_temperature') | list }}
{{ my_list | map('slugify') | map('regex_replace', '^(.*)$', 'sensor.\\1_humidity') | list }}
Or something even more ugly like a for loop with a namespace:
{% set ns = namespace(t=[], h=[]) %}
{% for room in my_list | map('slugify') %}
{% set ns.t = ns.t + ['sensor.%s_temperature' % room] %}
{% set ns.h = ns.h + ['sensor.%s_humidity' % room] %}
{% endfor %}
{{ ns.t }}
{{ ns.h }}
Would be nice to have format filter that took the format string as the second argument so this was possible without needing to know how regex and group matches works:
{{ my_list | map('slugify') | map('format', 'sensor.%s_temperature') | list }}
{{ my_list | map('slugify') | map('format', 'sensor.%s_humidity') | list }}
Currently there is a format filter but it takes the format string as the first argument so its not very useful with map
Or filters that allow you to append and insert text (since formatting can still be pretty technical):
{{ my_list | map('slugify') | map('insert', 'sensor.') | map('append', '_temperature') | list }}
{{ my_list | map('slugify') | map('insert', 'sensor.') | map('append', '_humidity') | list }}
There’s operators for these things when you have a single piece of text but no easy way to do it when you have a list of text.
