Currently it is complicated to distinguish between whether an attribute doesn’t exist or it does exist but is equal to None
Docs suggeset that testing for None
should be done by either of these two methods:
state_attr('sensor.my_sensor', 'attr') is none
state_attr('sensor.my_sensor', 'attr') == None
But those will both also yield True
if the attribute is not defined.
is_state_attr('sensor.my_sensor', 'attr', None)
will return False
in every scenario, so is not helpful.
The only viable method is to obtain the state object, and then these two options are possible:
states.sensor.my_sensor.attributes.attr == None
states.sensor.my_sensor.attributes.attr is defined and state_attr(my_sensor, 'attr') == None
But both require obtaining the state object first.
WTH isn’t there a test, filter, or function we can use on an entity_id
