Yes please add a building block integration component to allow unified user code management for locks, (i.e. please add building block integration component to allow unified user code management for locks).
Paraphrasing based on the idea from this architecture discussion → Native lock code functionality · home-assistant/architecture · Discussion #1000 · GitHub which was started over a year ago by @raman325 who a little time after that also started coding and maintaining a “Lock Code Manager” (a custom component that currently only works with the Z-Wave JS integration). See forum thread about that custom component here:
And the code for that custom Lock Code Manager component in its GitHub repository:
Suggested in a built-in lock platform (built-in integration building block) that would natively allow users to control the lock state of a lock (i.e. smart lock control), but it is currently not possible, at least natively, to manage user codes for the lock (i.e. users PIN-codes management). While not all locks have this functionality, many integrations/protocols does support this, including the built-in Z-Wave JS, ZHA (Zigbee Home Automation), and the Matter integrations, as well as some proprietary WiFi/BLE smart locks.
Today, those integrations are forced to more or less handle all lock code management on their own, (as an example, there are zwave_js specific services to manage user codes, but there isn’t a native UI that makes them easily manageable). As a result, there are custom integrations like GitHub - FutureTense/keymaster: Home Assistant integration for managing Z-Wave enabled locks which hack together a solution using a combination of the Home Assistant packages functionality, input helpers, and automations. In addition to generating a lot of artifacts which pollute a user’s instance, the UI that gets created is not optimized for the use case and is quite complex given what it’s trying to accomplish.
PS: Also check out the extended feature request about locks that was posted a few months ago here:
Paraphrasing based on the idea from this architecture discussion → Native lock code functionality · home-assistant/architecture · Discussion #1000 · GitHub which was started over a year ago by @raman325 who a little time after that also started coding and maintaining a “"Lock Code Manager” (a custom component that currently only works with the Z-Wave JS integration). See forum thread about that custom component here:
The built-in lock platform (built-in integration building block) natively allows users to control the lock state of a lock (i.e. smart lock control), but it is currently not possible, at least natively, to manage user codes for the lock (i.e. users PIN-codes management). While not all locks have this functionality, many integrations/protocols does support this, including the built-in Z-Wave JS, ZHA (Zigbee Home Automation), and the Matter integrations, as well as some proprietary WiFi/BLE smart locks.
