I have a lot of input_selects and selects in my config.
I can use a custom:buttoncard with select_next on tap to go through all the options.
Unfortunately there is no similar function for the select entities
Don’t forgot to vote yourself
While you wait, that functionality is scriptable…
Select Next
alias: Select Next
fields:
target_entity:
description: |
The select entity you wish to change
selector:
entity:
domain: select
example: select.basement_scenes
required: true
sequence:
- variables:
options: "{{ state_attr(target_entity, 'options') }}"
count: "{{ options|count }}"
current: "{{ options.index(states(target_entity)) }}"
new: |
{%- if current == count - 1 %}
{{ state_attr(target_entity, 'options')[0] }}
{%- else %}
{{ state_attr(target_entity, 'options')[current + 1] }}
{%- endif %}
- service: select.select_option
option: "{{ new }}"
entity_id: "{{ target_entity }}"
mode: single
Select Previous
alias: Select Previous
sequence:
- variables:
new: |
{% if current == 0 %}
{{ state_attr(target_entity, 'options')[-1] }}
{% else %}
{{ state_attr(target_entity, 'options')[current - 1] }}
{%- endif %}
option: "{{ new }}"
fields:
target_entity:
description: |
selector:
entity:
domain: select
required: true
mode: single
Select Last
alias: Select Last
sequence:
option: "{{ state_attr(target_entity, 'options')[-1] }}"
fields:
target_entity:
description: |
selector:
entity:
domain: select
required: true
mode: single
Select First
alias: Select First
sequence:
option: "{{ state_attr(target_entity, 'options')[0] }}"
fields:
target_entity:
description: |
selector:
entity:
domain: select
required: true
mode: single
Thanks @Didgeridrew, that helps me already !
