WTH is there no way to see the solar prediction in the past
The integration solar prediction shows you the current solar prediction in the energy dashboard. But there is no way to see previous predictions (this way you can either adjust prediction, or see if solar panels aren’t producing as much energy)
The problem is the Forecast.solar integration. If you use Solcast integration (“very a lot better”) the old prediction is available for 1 year.
