Why is there no undo in the dashboard editor… I have deleted dashboard elements by mistake several times. The last time I downloaded my latest backup and dug into the .storage folder opening the lovelace and finding my missing item… However it took quite some effort and reformating for the card to work again …
Also would benefit when some community integrations go through revisions that change how the dashboard displays only to change it back in the next version. This isn’t even necessarily the result of the integration developer, but sometimes the API the are using for the integration.
Versioning on all files would be nice
At least the last “delete” action can be undone:
For those moments where you realize you’ve just deleted a custom card that took ages to get just right. Sure you could revert to the previous backup, but it sure would be nice if you could just hit the undo button. Same when editing YAML.
Many people keep config in yaml which allows them to:
- use Ctrl-Z
- keep source code in Git (version control - yes, needs learning) or at least in Dropbox (which supports history in some extent).
But surely you may keep config in UI and hope that someone someday will add a functionality to keep a history of all changes (((
Agree completely with this, nothing more frustrating than accidentally making some changes and nuking your previous configuration. Would go further to say not just undoing but keeping a history of the changes, so if you nuke something without realizing much later, you can go back to a previous version.
Jetbrains local history saves my skin regularly but it does not work with anything not defined in a YAML file, so not really helpful if editing YAML via the UI.
I love git but a even a lot of the devs I work with already have no clue how to use it. A simplified UX with git being used in the backed could work though.
If edits weren’t applied immediately when edit mode was on, and the “done” button brought up a keep/revert option, that would do the trick.
i agree with this - I’m surprised there is no versioning system for the HA dashboard’s yaml.
i think the best solution HA could implement - is how Grafana handles this (which has alot of similarities to the Dashboard part of HA).
Grafana has a web UI to edit/modify/(or add) “panels” to your Grafana dashboard (which is saved in JSON → database) - you can also directly edit that JSON file in the web UI. At every SAVE event (user initiated by clicking save button), a version is saved, you can then show those changes (diff) , or compare versions, or restore to a version (or restore a version to a new/different dashboard).
I feel this is very similar to home assistant, in that a web ui is how some edit their dashboard and/or add cards, Then that is translated into yaml file (which you can directly edit also, just like the JSON file in grafana).
example of the grafana versioning for a dashboard:
(Unfortunately I’m not a coder, so this is all that I can contribute)
I (and surely averybody else) would highly appreciate an undo button.
I would even say, that this is an essential feature missing.
This is crazy that there is not a reliable way to undo with a button. An Undo button seems to pop up but often disappears again before you can even blink. The main solution that many mention is to set up git repos and commit often. But this is cumbersome when you are wanting to just play around with testing cards in the UI.
Please add “Undo” to a menu somewhere!
Since yesterday (deleting a part of the dash by accident) I found there is no way for an easy restore, undo or revert.
Would be a great feature.
Yeah I just got cooked by this, albeit I was fast 'n loose in what I was doing…copy/pasting entire dashboards…
But I was on the wrong dashboard and pasted a whole other dashboard on it, and BAM, gone! And I’m just working out that the backup recovery process for jsut a Dashboard is likely too prickly to do.
+1 to this. Doing complex dashboards sometimes feels like a extreme sport
+1 for a backup/undo/clone options for dashboards
IMO it’s insane that such a complex section of HA misses these basic features
Yep, another vote for this.
Just deleted my most complicated view because I’d carefully created a second view to test with, all worked, copied it into the main view, went to delete the secondary one and BAM, lost the main one instead - completely gone.
I get that the mobile app isn’t the most friendly editting environment, but losing the entire dashboard with no UI recourse is just nuts. I even tried killing the app so nothing would save, but nope – all changes are final and immediate.
Here’s hoping I can pull apart the backup tar file for just the dashboard yaml…
(it’s just text; paste it into a database table every time it changes - at least then it could be a simple version history users could browse, with or without pretty diffs).
