It’d would be great if we could set how many traces we can scroll back in the automations for debugging. It appears you can only go back 5.
I’m guessing you missed the automation documentation which explains how to set a number other than 5?
Is there a way to change the default? That method requires every automation to be edited.
So my vote is for changing the default to more than 5 (if there isn’t already a way to do it)
The default number of stored traces is a hard-coded constant:
@OptimusGREEN can you edit the WTH or close & create a new one to make the default trace count a configurable value.
It’s … in the link I posted
It already is configurable, hence my first response in this thread that linked to the documentation showing how to change it
