I am often in a situation where what I want a script or automation mode that is essentially “queue 1 call and keep only the most recent call.” A simple example is a script that sets the brightness of a specific light. If it is called multiple times in succession while still running, the ideal thing would be to finish the current call and then start a new call with only the most recent brightness rather than setting all the settings in between in sequence or, worse, dropping the most recent calls once a queue is filled.
Sometimes “restart” works for this purpose, but sometimes a script has other effects where it would be undesirable to cancel it. The difference between this and a queue of length 1 is that a second call while it’s still running is currently dropped, and I would like that call to replace the old one in the queue. You could generalize this to a “stack,” keeping the most recent n calls (analogous to a queue of length n). I don’t personally have many uses for stacks bigger than 1, but maybe others do, and this would work for my purposes.
[Edit: In a response I created an example which I think makes it clearer; copy/pasted it here.]
Let’s assume I have a script that sets a light to a brightness and then waits 5 seconds. I then call the script 4 times rapidly, in order A B C D, with different brightness (say, 63, 127, 191, 255). My goal would be that A runs to completion, after which D runs to completion, and B and C are dropped. I assume this would be done by holding the most recent call in a single-call buffer, replacing it with a new call when it comes in and the original is still running. So the sequences is:
A starts running, sets brightness to 63, and continues for 5 seconds, during which…
B gets put in the buffer while A is still running.
C replaces B in the buffer while A is still running.
D replaces C in the buffer while A is still running.
A completes, and D immediately runs, setting brightness to 255 (and then sleeps 5 seconds).
And apologies if there’s a way to do this now and I just haven’t found it. Thanks!
Thanks for the idea! I’m not quite seeing how this does what I’m hoping to do here. I think adding that condition will simply make it not run if it’s already running, which would be equivalent to the “Single” mode except wouldn’t produce a warning.
Maybe it’s easier if I give an example. Let’s assume I have a script that sets a light to a brightness and then waits 5 seconds. I then call the script 4 times rapidly, in order A B C D, with different brightness (say, 63, 127, 191, 255). My goal would be that A runs to completion, after which D runs to completion, and B and C are dropped. I assume this would be done by holding the most recent call in a single-call buffer, replacing it with a new call when it comes in and the original is still running. So the sequences is:
I think with the condition, only A runs. But apologies if I’m misunderstanding!
