Continuing the discussion from WTH. Script execution stops after a condition step in script sequence, rather than continue past:
Iām beginning to believe that the choose
construct was a mistake. It seems to confuse everyone.
I think this would be better (and now that Iāve had a chance to think about it more, it wouldnāt really be any more difficult to implement than choose
was):
- if:
<conditions>
then:
<actions>
- elif:
<conditions>
then:
<actions>
- else:
<actions>
where <conditions>
are one or more conditions:
- if:
- condition: state
entity_id: binary_sensor.abc
state: 'on'
- condition: template
value_template: "{{ abc == '123' }}"
and <actions>
are one or more actions:
then:
- service: script.abc
- event: xyz
and elif
and else
are both optional, meaning you could use one, or the other, or both, or neither.
So if no condition is true no action is performed without generating an error?
I raelly liked how elegant this solution this was:
But it would work just as well with if / else.
Why would there be an error? Yes, āif FALSE then Xā would mean donāt do X. Why is that unclear in any way?
The elegant solution you linked to (if āif-elif-elseā was available as I proposed), would just look like this instead (but would be exactly equivalent):
- id: light_dependency
alias: Light dependency
description: "Switch lights to same state"
platform: state
entity_id: light.patio
- if:
value_template: "{{ trigger.to_state.state == 'on' }}"
then:
- service: light.turn_on
entity_id:
- light.garden
- elif:
value_template: "{{ trigger.to_state.state == 'off' }}"
then:
- service: light.turn_off
entity_id:
- light.garden
Think jinja. Iāve lost count of the number of times Iāve told people they need an else case to cover all eventualities.
Thatās totally different. If youāre using service_template
, then the template must provide a service, because youāre basically saying ācall a service, but let me figure out which one first.ā But an if action is only doing something if the conditions are true. Itās the difference between:
Do X if Y
vs
If X do Y
In the former (which is like a service_template
), if X is false then youāve said do something, but did not provide what to do.
In the latter (which is like an if
action), if X is false then you havenāt said to do anything.
Iām trying to think this trough. Iām creating a pseudocode choose
, adding if, then, else
statements as comments. That is easier for me to think about them that way.
- choose:
- conditions: # If
<user is Phil>
sequence: # then
<Phil's action>
- conditions: # elseif
<user is Tom>
sequence: # then
<Tom's action>
default: #else, then
<Alternate user action>
Yes, a choose
action can be used like if-elif-else. In fact, thatās what it really is. But it seems to confuse a lot of people. Iām not sure why, but it does.
The structure isnāt not obvious, the indents seem inconsistent. I think choose
is one I will always have to copy reference code to get started. I donāt think I will ever get it right if I try to type it manually. For example it breaks my brain that default
is at a different level than the conditions
. My brain wants the else
to be at the same level as the elseif
's.
Maybe my example would look like this?
- if:
- conditions:
<user is Phil>
then:
<Phil's action>
- conditions:
<user is Tom>
then:
<Tom's action>
- else:
Or the else
could look like this?
- else:
then:
Not based on what Iām proposing. It would be:
- if:
<user is Phil>
then:
<Phil's action>
- elif:
<user is Tom>
then:
<Tom's action>
- else:
So we could omit the - conditions:
and just get to a condition. If thatās possible, that would be nice. But either works in my mind.
this
I try to live by the motto, āItās never too lateā But I realize that once published and people start using it, itās super painful to pull it back. So I guess we live with it and just document. Or could if / else be introduced as aliases for conditions to get most of the way there?
IMO, eliminating the duplicated items would be even more āelegantā. I know this isnāt valid yaml, but Iām thinking of something like:
platform: state
entity_id:
- light.garden
if:
- then:
- else:
As for why choose confuses people, for me itās the conditions: part. I only see one mention of it in the documentation: Script Syntax - Home Assistant and it is super simple. It isnāt clear to me from it how multiple conditions would work - are they AND or OR? And how do multiple ELSEās fit into the example? And separately, despite having programmed in various languages off and on for 40 years, I canāt wrap my head around how the else in the example makes sense given the indention. Course, Iām still not a yaml expert, so that may be part of the problem (for me and others).
Perhaps the āelegantā example could be added to the documentation, and maybe the example in the 0.113 notes (or point to that example) as well. In both cases, a few comments pointing out the parallel to if, elsif, else would go a long, long ways.
Mostly unrelated, but I just noticed it isnāt mentioned on the automations documentation page, only the scripts page.
Follow the link to the conditions page and it explains it there, because itās the same everywhere multiple conditions are accepted. It canāt be explained over and over again everywhere. That would not be maintainable.
Yep, thatās definitely part of the problem for new users.
Itās definitely on my to-do list to enhance the documentation for the choose
action.
Itās on the āscript syntaxā page, which is used by both the scriptās sequence
section and the automationās action
section. (An automation is really nothing but a script with trigger/condition tacked on to decide when to automatically run the actions.) I have a PR somewhere in the stages of release that reorganizes the script & automation pages somewhat to make it clearer, but itās stuck somewhereā¦
