I did install this using few several methods: using preinstaller from web, using manual yaml etc… there is no media player service endpoint created for it.
this my latest config from m5stack.yaml after adoption:
substitutions:
packages:
m5stack.atom-echo: github://esphome/media-players/m5stack-atom-echo.yaml@main
esphome:
name_add_mac_suffix: false
ota:
password: !secret ota_password
wifi:
ssid: !secret wifi_ssid
Probably , you have already sort this out but here it goes for anyone still looking for:
media_player:
- platform: i2s_audio
dac_type: external
i2s_dout_pin: GPIO22
mode: mono
This is an issue I am currently having. As I am new to Home Assistant I am fumbling my way around and learning. That said, I have no idea where this code is supposed to go. Can someone enlighten me, please?
@freedombeard I would say it goes into your ESPhome YAML code, which you can edit in the ESPHome dashboard by clicking “Edit” next to the device name
Ah, that was a major part of my problem; I hadn’t installed ESPhome. Home Assistant had automatically added the Atom Echos it found.
So, now I’ve installed ESPhome and added the device. My yaml file looks exactly like OP’s now. I can now add the above media_player code from @miguelromao but I get this error: “This feature is only available with frameworks [‘arduino’].”
My assumption is that media_player is already defined in (and copied/installed to the device itself):
If so, how do I call it in an automation? So far as Home Assistant is concerned a media_player.m5stack-atom-echo-xxxx does not exist. I can manually type it in (replacing - with _) and the automation runs without error. But, it does not actually play the text to speech phrase I’ve told it to (via PiperTTS.)
I added the following to my atom echo esphome configuration and the media player now shows up and works.
Can you paste the YAML code please. Makes it easier to copy/try out.
Just add this to your existing esphome yaml configuration and install it on the atom echo.
esp32:
board: m5stack-atom
framework:
type: arduino
media_player:
platform: i2s_audio
dac_type: external
mode: mono
The biggest problem I’ve had with using the Atom Echos as a media_player is that every time I try to play something on it, the first time it seems to work but subsequently trying to play another MP3 sets the thing in “busted” mode and it no longer plays any music nor speech until I reboot it. It’s like the media_player looses it’s mind or something. Not very useful.
I’m having a similar issue. I dont ever get media playing. I have installed the voice assistant, so I know the speaker works. I reinstalled. My config for the M5Stack Echo Atom:
esphome:
friendly_name: M5Stack Atom Echo
name_add_mac_suffix: true
project:
version: "1.0"
min_version: 2023.5.0
esp32:
board: m5stack-atom
framework:
type: arduino
logger:
api:
ota:
dashboard_import:
package_import_url: github://esphome/firmware/media-player/m5stack-atom-echo.yaml@main
wifi:
ap:
captive_portal:
improv_serial:
i2s_audio:
i2s_lrclk_pin: GPIO33
i2s_bclk_pin: GPIO19
microphone:
i2s_din_pin: GPIO23
adc_type: external
pdm: true
voice_assistant:
microphone: echo_microphone
on_start:
- light.turn_on:
blue: 100%
red: 0%
green: 0%
effect: none
on_tts_start:
- light.turn_on:
blue: 0%
red: 0%
green: 100%
effect: none
on_tts_end:
- media_player.play_media: !lambda return x;
- light.turn_on:
blue: 0%
red: 0%
green: 100%
effect: pulse
on_end:
- delay: 1s
- wait_until:
not:
media_player.is_playing: media_out
- light.turn_off: led
on_error:
- light.turn_on:
blue: 0%
red: 100%
green: 0%
effect: none
- delay: 1s
binary_sensor:
- platform: gpio
pin:
number: GPIO39
inverted: true
on_multi_click:
- timing:
- ON FOR AT MOST 350ms
- OFF FOR AT LEAST 10ms
then:
- media_player.toggle: media_out
- timing:
- ON FOR AT LEAST 350ms
then:
- if:
condition:
then:
- media_player.stop: media_out
- voice_assistant.start:
- timing:
then:
- voice_assistant.stop:
media_player:
dac_type: external
mode: mono
light:
platform: esp32_rmt_led_strip
pin: GPIO27
default_transition_length: 0s
chipset: SK6812
num_leds: 1
rgb_order: grb
rmt_channel: 0
effects:pulse:
transition_length: 250ms
update_interval: 250ms
The log:
INFO ESPHome 2023.10.6
INFO Reading configuration /config/esphome/m5stack-atom-echo-8a2098.yaml…
INFO Starting log output from m5stack-atom-echo-8a2098.local using esphome API
INFO Successfully connected to m5stack-atom-echo-8a2098.local
[18:28:52][I][app:102]: ESPHome version 2023.10.6 compiled on Nov 10 2023, 18:16:46
[18:28:52][I][app:104]: Project m5stack.atom-echo version 1.0
[18:28:52][C][wifi:546]: WiFi:
[18:28:52][C][wifi:382]: Local MAC: 64:B7:08:8A:20:98
[18:28:52][C][wifi:383]: SSID: [redacted]
[18:28:52][C][wifi:384]: IP Address: 10.174.183.140
[18:28:52][C][wifi:386]: BSSID: [redacted]
[18:28:52][C][wifi:387]: Hostname: ‘m5stack-atom-echo-8a2098’
[18:28:52][C][wifi:389]: Signal strength: -51 dB ▂▄▆█
[18:28:52][C][wifi:393]: Channel: 7
[18:28:52][C][wifi:394]: Subnet: 255.255.255.0
[18:28:52][C][wifi:395]: Gateway: 10.174.183.108
[18:28:52][C][wifi:396]: DNS1: 8.8.8.8
[18:28:52][C][wifi:397]: DNS2: 8.8.4.4
[18:28:53][C][logger:416]: Logger:
[18:28:53][C][logger:417]: Level: DEBUG
[18:28:53][C][logger:418]: Log Baud Rate: 115200
[18:28:53][C][logger:420]: Hardware UART: UART0
[18:28:53][C][esp32_rmt_led_strip:171]: ESP32 RMT LED Strip:
[18:28:53][C][esp32_rmt_led_strip:172]: Pin: 27
[18:28:53][C][esp32_rmt_led_strip:173]: Channel: 0
[18:28:53][C][esp32_rmt_led_strip:198]: RGB Order: GRB
[18:28:53][C][esp32_rmt_led_strip:199]: Max refresh rate: 0
[18:28:53][C][esp32_rmt_led_strip:200]: Number of LEDs: 1
[18:28:53][C][gpio.binary_sensor:015]: GPIO Binary Sensor ‘Button’
[18:28:53][C][gpio.binary_sensor:016]: Pin: GPIO39
[18:28:53][C][light:103]: Light ‘M5Stack Atom Echo 8z2098’
[18:28:53][C][light:105]: Default Transition Length: 0.0s
[18:28:53][C][light:106]: Gamma Correct: 2.80
[18:28:53][C][captive_portal:088]: Captive Portal:
[18:28:53][C][mdns:115]: mDNS:
[18:28:53][C][mdns:116]: Hostname: m5stack-atom-echo-8a2098
[18:28:53][C][ota:097]: Over-The-Air Updates:
[18:28:53][C][ota:098]: Address: m5stack-atom-echo-8a2098.local:3232
[18:28:53][C][api:139]: API Server:
[18:28:53][C][api:140]: Address: m5stack-atom-echo-8a2098.local:6053
[18:28:53][C][api:142]: Using noise encryption: YES
[18:28:53][C][improv_serial:032]: Improv Serial:
[18:28:53][C][audio:203]: Audio:
[18:28:53][C][audio:225]: External DAC channels: 1
[18:28:53][C][audio:226]: I2S DOUT Pin: 22
[18:29:25][D][media_player:059]: ‘M5Stack Atom Echo 8z2098’ - Setting
[18:29:25][D][media_player:066]: Media URL: http://homeassistant:8123/api/tts_proxy/eee0b150898a52492e40c392320ffd3a349922b7_en-us_-_google_translate.mp3
[18:29:25][W][component:214]: Component i2s_audio.media_player took a long time for an operation (0.58 s).
[18:29:25][W][component:215]: Components should block for at most 20-30ms.
[18:29:26][W][component:214]: Component i2s_audio.media_player took a long time for an operation (0.44 s).
[18:29:26][W][component:215]: Components should block for at most 20-30ms.
I’ve been doing a ton of digging on this and found the following:
- The default config for voice assistant on ESPHome doesn’t use media_player; it uses the speaker component instead
- There is currently a shortcoming where the ESPHome media_player cannot play raw audio files; this is a problem because piper currently returns raw audio files
See: Wyoming integration returning incorrect URLs from piper · Issue #92969 · home-assistant/core · GitHub
Hopefully the PR for ESPHome that enables support for RAW will get merged in: Add support for raw files by robin-thoni · Pull Request #12 · esphome/ESP32-audioI2S · GitHub
But more hopefully than that is that the fix to the HA voice assistant integration makes it way to a release version:
Although, since it’s labeled as a breaking change, I’m going to guess the wait for that is going to be a little while.
