Why do we need to create sensors that fill up the database only to display calculated values in the UI ?
Simple exemple: I want to display absolute humidity. I have sensors for relative humidity and temp. To get what I want, I just need to do a few maths.
It would be realy usefull if cards could accept a template.
This feature could be supported only in yaml, no problem, if you can write templates, you can write yaml.
When template is specified, default action on card becomes none.
Thanks for reading
PS1: this is a repost. I have already posted this in the wrong category. I asked deletion of original post.
PS2:vingerha suggested to use this plugin GitHub - iantrich/config-template-card: 📝 Templatable Lovelace Configurations. It’s a good catch, but something built-in would be better.
