WTH Month: Why can't we add template entities from the UI?
I use template entities a lot (template sensor, template binary_sensor, etc). Each time I change them inside the configuration.yaml file, I have to reload Home Assistant for it to reflect the changes. It would be great if this worked via the UI so I can dynamically edit and preview live the template result/icons/etc.
