WTH - no copy/paste on card/view/badges visibility conditions?
I’m making use of the awesome visibility feature on cards and dashboards. It’s a really great feature!
That said, WTH can’t I copy and paste conditions between respective cards and/or dashboards?
On the not of copying and pasting, I wanted to link another WTH with the hopes that “if” this WTH gets implemented, that it would be with similar functionality as requested over here.
Was just about to open one like this and saw yours. My text would have been:
With the new lovely badges you can set visibility. Some might need the same and some might be complex settings, it would be great to copy the conditions as single or total and past it on another badge, same as possible in automations and scripts.
Maybe you can add badges in the title as well?
For sure. I hadn’t played with badges much, but happened to last night and noticed it would be good to have better management with them too, same changes right?
My case was using badges to show some access control entities on a shared dash. I’ve got them set to “nothing” when you tap, but I’d prefer to make another set that only shows for me that allows normal actions. I’ve done that with cards and visibility, but when I noticed I couldn’t copy and paste I decided it wasn’t worth the time at the moment.
100% agree with this. Everything should be able to be copied and pasted in the UI, there are a few things that aren’t, like visibility
I have to double check, but some of these are not even available in YAML without using the full raw dashboard configurator which is overwhelming for a small tweak.
