I was playing around with text to speech… And discovered that there is no Portuguese text to speech? Am I missing something? Or is Home Assistant missing half a billion people on earth?
There are 3 voice options for Portuguese voices in Piper - Voices.
You should not need to download them if you are using the Piper Add-On, just choose the one you want from the dropdown in the add-on’s configuration tab.
Thank you Didgeredrew, I will look into that.
I am not quite sure what has happened, but after some tinkering with piper I got even the Home Assistant (cloud) tts to speak Portuguese. Even European or Brazilian!
