WTH no sections in history graph card
Why can’t you add section lines/labels in the history graph card, like you can with entity card?
I’m having trouble visualising what you mean by this. Can you post a mock-up screen shot?
Here is an example, using the section labels from the standard entity cards mixed with the history graph cards. Separates various motion sensor histories based on which systems are providing the sensor values.
And the associated Lovelace yaml:
type: history-graph
entities:
  - entity: binary_sensor.motion_sensors
  - type: section
    label: ADT
  - entity: binary_sensor.adt_motion_sensors
  - entity: binary_sensor.north_warehouse_motion
  - entity: binary_sensor.south_warehouse_motion
  - entity: binary_sensor.south_office_motion
  - entity: binary_sensor.north_office_motion
  - type: section
    label: Tasmota
  - entity: binary_sensor.tasmota_motion_sensors
  - type: section
    label: Frigate
  - entity: binary_sensor.frigate_motion_sensors
  - entity: switch.XXX_dome_motion
  - entity: binary_sensor.XXX_entry_motion
  - entity: binary_sensor.XXX_corner_motion
  - entity: binary_sensor.XXX_dome_motion
hours_to_show: 8
title: Motion
refresh_interval: 60
If you do this as separate history graph cards the problem is that the timelines do not match up since the width of each bar is dynamically adjusted based on the text length of the name displayed on each sensor line.
Yeah I’ve got a similar issue with the history-graph, but on mine I’m displaying an input_select and a sensor value. The timelines don’t align as the input_select line doesn’t start at the same position as the sensor graph, due to the text.
