Instead of having to leave an automation you are working on to go to a script that is being called as an Action it would be great if we could open the script directly.
All scripts are services that can be called from an automation.
What I mean is to be able to open the script from within the automation I am working in so I can edit/update that script instead of needing to leave editing the automation to then go open the script.
open a 2nd window?
Hint, if you open one of these, it’s a good idea to vote for it or else you might end up with 0 votes, like this. Otherwise it looks like you don’t think it’s a good idea.
