WTH - provide a bulk clean-up for removed entities
If you keep your HA instance running for long enough, the integrations change or refine the set of entities which get exposed for every device, and you end up with a bunch with the message:
“This entity is no longer being provided by the xyz integration. If the entity is no longer in use, delete it in settings.”
Can these be put into a “Repair” under settings, where you can bulk clean them via a single click?
Closed as a duplicate. Please search the category before posting. You can vote and comment here: WTH there isn't a System Cleanup and/or here: WTH missing entity repair items
