I want to have a button that reruns a step in a script using the tracing window.
You can run steps manually in the editor. But when you have a big script and you want to debug a script.
You might want to rerun a step if this step uses information from other steps and executes some self made code that contained a bug.
Then you can rerun the step untill fixed instead of running the whole script again.
This could easily be implemented and makes a lot of users happy.
