WTH Sanity check for energy readings
Why are there no sanity checks for energy meters. I see from time to time, the Z-wave/zigbee energy meters get a bad reading of the kWh, so it goes from 125kWh to 1.500.000 and then back to the “normal”
Why not have a sanity check, can filter this out
I agree, there is a built in filter, but that means you are creating a new entity and some how I feel that I don’t need more than necessary…
So there should be a possibility to filter the original entity regarding as you say spikes, or when an incremental entity suddenly is lower than the previous…
I get a random negative readings which means my dashboard for energy is all wonkey. Would be nice if I don’t have solar or its a smart plug then I should never have negative readings.
After moving to our current house, I hooked everything up again to run HomeAssistant and other things at our new place. Shortly after I got energy readings, I noticed that our energy and gas usage went through the roof in the exact week we moved in… According to HomeAssistant, that is :slight_smile:
We are aware and taking action to reduce our energy usage, but we supposedly used about 18.000 kWh and 2943 m3 in one week? Even for a workshop, that’s a lot and we don’t own one :slight_smile:
I went searching in the homeassistant database, but no luck so far.
There is a tool for fixing these kinds of accidents: Developer tools > statistics > adjust sum
Ooh, that’s a nice trick thanks!
Would be nice though if this kind of filtering would happen automatically. I mean we’re doing statistics here, so given an a priori Bayesian distribution, what is the probability of a sample being larger than the mean plus two times standard deviation? 2.5% which is actually quite large in this particular case :innocent:, but you get the idea.
Finally found the time to further look into this. It took a while to find the precise entry, even after I determined the date of the entry should be around July 12/13th. But I found the entries which caused the “problem”, replaced the values with statisticly correct (well, more or less) ones, and that fixed the spikes :slight_smile: Thank you for your great tip!
I believe this is caused by an integration not sending the correct values. I had similar problem with mine and was due to the MQTT defaulting to 0 when there was no data rather than unavailable. This meant that at startup it would default to 0, then some time later get a reading of like 1,500,000 which would show as a spike, then continue with the normal increasing values…
After setting the values to unknown until there was actual data completely fixed this issue.
