WTH Template editor on automation/script traces
It would be really cool if there could either be a template editor inside the trace UI or if you could launch the template editor from there and have all of the variables in changed variables of the trace loaded in.
This would be useful, for instance, if you wanted to edit a template that was using anything about an automation’s triggers or a scripts parameters.
You can do this yourself by mocking up the trigger or parameter variable, but it sure would be nice to do this more effortlessly.
