When I cast my dashboard to my nest hub. The background doesnt load
I’ve added a similar WTH. I was experimenting over the weekend and discovered that if you specify your background image using an external path, it’ll work.
For example, you can test with any public image
Ah thank you!
Out of curiosity, are you using Nabu Casa, and have you set up a custom domain, and is that custom domain the name name as one you use on an internal DNS server? Pretty edge case I know, but I’m trying to get to the bottom of this as I think this might be a bug.
