WTH - There is no way to copy a helper?
I just installed 4 plant sensors and wanted to add sensor templates for
Min temperature
Max temperature
Min humidity
Max humidity
Min lux
Max lux
Min conductivity
Max conductivity
I was confused to be unable to create copies of these for my other 3 plant sensors. I had to create all of the above for all 4 sensors manually… that was a lot of work.
Is anybody aware of a way to copy helpers? I never want to do this again
Not via the UI.
Some helpers can be defined in YAML (like Template Sensors) and then it’s trivial to create copies.
Duplicate
