Over the summer our thermostat (managed by the Honeywell Total Connect Comfort (US) integration) was set to the same temperature overnight every night. The graph never showed any A/C activity at any point when the thermostat and temperature were both at this setting, because that temperature became the bottom of the graph. Since I found no way to change the y-axis values, there was no way to see how often the A/C came on to keep the temperature at the overnight setting.
I would like to have the graphing code always set the lowest y-value of the graph to something below the set temperature so I can see how often the A/C was on.
Unfortunately the data all expired since it got colder or I would show the issue, but hopefully this is clear enough.
Thanks folks!
