I have a boiler, I set and automation to stop it after two hours of runing, if HA in restarted during that runing period the boiler is never shutted of.
platform: state
entity_id:
- switch.boiler
to: "on"
for:
hours: 2
minutes: 0
seconds: 0
Those triggers should be relaeded at startup to avoid this kind of annoyance
You should be aware, it’s not just if Home Assistant restarts, it’s also if you edit any automation. Basically any action that causes Home Assistant to reload all the automations.
