You can change the device_class
of a binary sensor via the “Show as” selector in the UI, but this functionality is not available for (non-binary) sensors. It would be great to have similar functionality for the sensor domain.
Example: I use the min/max/mean helper to create average temperature measurements from multiple temperature sensors. However, the min/max/mean sensor does not inherit a device_class
or icon from the constituent sensors, and the only way to set the appropriate device_class
is through YAML.
