Starting thread for the user community of the lovely dutch floorheating controller from WTH: The UMR Vario (v1). I am new to Home Assistant custom integrations, but on a quest to provide home automation for this older product. See the threads on thee WTH UMR2, which already has custom integrations (written by the open source community. This thread is not for the UMR2, but the older (~2010) UMR Vario.
What i have sofar in terms of working towards an integration with Home Assistant:
List item USB (mini): The UMR Vario has a mini usb port which, according to manuals, can be used by installer parties to debug, read values and configure the Vario. Based on internet research the software is called VarioControl. I have not been able to verify this, nor find any more information about what the software is able to read or write to the controller. Without installer software its is just a device on a COM1 / Serial Port.
List item Bluetooth: Ditto as the above; standard bluetooth client doesnt show much info; it just pairs and waits for the installer software to start doing something.
List item C1101 RF: The main living room thermostat communicates over 868mhz. Its an older board (2010), so my theory is that the signal likely does not contain rolling code implementation, so learning and resending the same signal will likely work. This is currently not confirmed
Currently my main use cases is to have access to read information on all thermostats in my house and at a minimum be able to set temperature on the living room thermostat. This could technically be achieve by just sniffing and learning RF signals to the main thermostat (which in turn talks to the Vario’s C1101 RF module). However that would limit functionality to only the living room temp info and the features it contains (on/off, set temp, heating/cooling) and not give read access to other room temperatures.
I am currently still in research phase and want to work out what info is available, who is interested in this integration and if we can get WTH to collaborate. Based on that i will decide whether to reverse engineer the RF signals (and stick with that) or use a Serial Port Analyzer to reverse engineer that and then plug it in a Pi (for example).
The Serial Port option basically follows what this user did in Domitica with a Pi: DomoticaVrijgave - WTH wiki and the Homebridge add-ons here: https://www.npmjs.com/package/homebridge-umr-controller?activeTab=code However, i cant work out how and where his NodeJS server is interpreting the serial messages communicated. Does homebridge take care of this? Maybe someone with more serial SRE knowledge can assist us here.
Any information welcome and also please share if you are interested in this integration.
Unfortunately this journey comes to an unsatisfactory end. My WTH Vario is V1.0. This is visible in the middle module, so not the one with the interface, but where all the actuators are wired to. Bottom left on this board you should see WTH UMR Vario V.xxx.
Offline i had some correspondance with Rolf Nooteboom (of Nooteboom Electronics). Rolf has been instrumental for the development of the Vario module versions. The domotica integration on https://www.wth.wiki is also his. If there are still folks interested, this integration could work for UMR Vario V3 (minimal version):
Vario V3 can unlock additional controllers (“vrijgave”). Follow the instructions on wth.wiki to unlock your vario. Then you could base the integration on the NodeJS module which was written for domotica. Unknowns in this approach is to what extend is reverse engineering of serial messages required. The old domotica code clearly doesnt contain it. Nooteboom Electronics hasnt answered this question either.
I also have the same system. Managed to unlock the “Domotica” setting via the instructions on the now-gone wth.wiki, but I can’t seem to be able to get any response on the serial port via USB (COM device gets detected fine though). I did save the instructions and the list of serial commands, in case those would be useful.
What a shame that there is no option. I also have a UMR Vario based underfloor heating system with cooling. The latter seems to be the issue, with just heating I could easily swap the WTH thermostat for another brand like Tado. But the WTH wired thermostat seems to communicate via a digital bus and also controls cooling mode. No 3rd party thermostat can do this.
My only choice appears to be an upgrade to UMR2 Plus with new wired thermostat and programmer. That’s a big effort and investment. Given I only have one zone, it doesn’t deliver enough convenience returns.
Correct! I upgraded to the UMR2 PRO (with my old thermostats using “powerstealing”) and now I can atleast read out all the thermostat current and set temperatures in all rooms, however these older thermostats I can’t set / change temperature.
UMR2 you could bind to your HA instance via ethernet or Bluetooth. After that its a simple setup with local IP and a local json file you can retrieve via HA rest call.
Last tip: monitor 2nd handsites (eh Marktplaats), they are posted quite often
What version is stated in the top right of the board? As stated i understood from the original board designer that v1.0 had a dummy usb port soldered to it, but it doesn’t actually send any serial messages. Later version of the UMR 1.0 Vario do seem to have it, but it wasn’t fully developed as WTH decided to scrap the project and go with a different company to develop the UMR2
