WTH we can't mark multiple automations for deletion
It would be helpful when you want to clean up the list of automations.
You can. Settings → Devices & Services → Entities tab.
You can select as many automations as you like and then press the “Remove Selected” button.
Sure, you can do it from entities list view, but it’s impossible to do it from the automations list view.
My point still stands.
Why one should go to other part of the settings when you’re creating/changing/deleting automations. We should be able to do it right there from the automation list view.
This does not work for me, to this day. I just tried it on the latest HA. I went to the entities tab and selected 4 automations and “Remove selected.” However, I get a weird message that “no items can be deleted” and it would not allow me to delete any. I have to select each one individually and delete, like a cave person.
Same. T"he others require the integration to stop providing them, and sometimes a Home Assistant restart is needed. Are you sure you want to delete the deletable entities? Remove them from your dashboard and automations if they include these entities."
