WTH, why are the logs not showed below Yaml Reload Menu?
It would be great if the logs window would be added below the yaml reload menu, to get direct feedback on errors when reloading.
When I change something in Home Assistant I usualy have to go back and forth between the logs and yaml reload, and it requires a lot of clicks at the moment.
Not putting down your request, but to make it easier for yourself, why not just open both in separate tabs? Pretty quick to flick between them then.
Or reload from logs via “c” shortcut, or have it open in another tab in VS Code, or some other “work around”…
I think it would be convenient to have them next to the reload menu.
As I said, not trying to put down your request, I was just trying to help.
You seem to know lots of ways to do it, without ‘lots of clicks’ arguing against yourself really
The new menu structure got a lot of complaints when it was introduced. Some of them have been fixed and I think this would make it even better.
It is not a critical bug or anything like that. But perhaps it is an easy improvement? I do not know enough about how the front end works to know if it is easy or not.
This, logs and reload in one place. Navigating to ‘Logs’ section takes too many clicks alone.
+1 would also like to see this :slight_smile:
