For some entities it is useful to be able to set there state without triggering the actions, it would be good to be able to change their state through an automation where they can change without Home Assisstant detecting them for example:
Overlapping groups of blinds, triggering All Blinds to close, I want the group Lounge Blinds and Kitchen Blinds group to close.
Remote control of AV equipment where people can change the state of devices without an event Home Assistant sees
When I close the All Blinds group to close all blinds the Lounge Blinds group shows as open. I would like to be able to set the Lounge Blinds group state to Closed without trigger the close action.
I checked and I incorrectly stated it was Cover Groups it is not it is Template Covers so they are not linked to the covers. The template covers use logic to detrmine what blinds to open or close this may result in a change of state to other template covers. I checked the documentation and I have found a way of manging this but is would be easier just to directly change the state of the template cover without triggering the action.
This applies to situations where the state of something can be changed externally outisde of HASS but there is no event. In the AV example if someone changes the source on the reciever this does not cause an event but may be detected later by polling which I can use to make the state in HASS consistent but I don’t want to trigger the action.
Using hdmi cec integration i can see state of my dumb tv, for reasons beyond my unerstanding state is geeting stuck from time to time, therefore i introduced a boolean sensor to keep pinging tv ip and report “real” state and fix it if its wrong.
This all works, however changing state also triggers action.
And no i cannot use this boolean sensor as part of template switch, because its much slower than hdmi cec, therefore:
