Sometimes my Zigbee or WiFi is malfunctioning, batteries are low, USB stick got disconnected or an online service stops working (thank you lufdaten!) Why can’t HA profile ‘healthy’ sensors and determine their normal behaviour (gas usage reports every hour, temperature roughly every 5 minutes, etc.) and notify me on irregularities. Too often it takes me days or even weeks to notice some sensor is not working.
Something like this?
type: 'custom:auto-entities'
card:
type: entities
title: Last Seen
show_header_toggle: false
filter:
include:
- name: /linkquality/
options:
secondary_info: last-changed
sort:
method: last_updated
reverse: true
card:
type: entities
title: Link Quality
filter:
include:
options:
sort:
method: state
numeric: true
card:
type: entities
title: Battery
filter:
include:
- entity_id: '*battery'
options:
not:
domain: automation
sort:
method: state
numeric: true
And an automation that notifies me:
- id: '1579893997207'
alias: Zigbee Drop Notification
description: ''
- at: '18:00:30'
platform: time
- at: '6:58:24'
platform: time
condition:
- condition: template
value_template: " {%- macro GetDroppedZigbee() -%}\n {% for state in states.sensor\
\ -%}\n {%- if state.attributes.linkquality %}\n {%- if \"Ikea\"\
\ not in state.name and \"linkquality\" in state.name and (state.attributes.linkquality\
\ < 15 or (as_timestamp(now()) - as_timestamp(state.last_updated) > (12 * 60\
\ * 60) )) -%}\n X \n {%- endif -%}\n {%- endif -%}\n \
\ {%- endfor %}\n {%- endmacro -%}\n\n {%- if GetDroppedZigbee()[0] ==\
\ \"X\" -%}\n true\n {%- else -%}\n false\n {%- endif -%}"
- data:
message: "Some devices haven't been seen lately or have low lqi... {% for state\
\ in states.sensor -%}\n {%- if state.attributes.linkquality %}\n {%-\
\ if \"Ikea\" not in state.name and \"linkquality\" in state.name and (state.attributes.linkquality\
\ < 15 or (as_timestamp(now()) - as_timestamp(state.last_updated) > (12 *\
\ 60 * 60) )) %}\n {{ relative_time(state.last_updated) }} ago for {{\
\ state.name | lower }} ({{state.attributes.linkquality}} lqi)\n {%- endif\
\ -%}\n {%- endif -%}\n{%- endfor %}\n"
service: notify.mobile_app_phone
Very good! Didn’t know about the last-changed option.
You could also consider hiding the “good” entities and only showing the ones that need attention to clean things up a bit. E.g. for my battery sensors I have it filtering on lower than 5% remaining which cleans up the overview a lot.
- entity_id: '*_battery'
state: < 5
thank you for your example… this will certainly help. Doesn’t cover my frustration completely. Some integrations or sensors are allowed to only report daily, while others (e.g. electricity) are supposed to trigger every 10s. Now I have to visually inspect my sensors (and there are many) and assess if they are working correctly. That is not do-able.
In config -> entities, click on the status column to sort by status and it will highlight all entities that are either unavailable as reported by the integration or unavailable because they are not currently provided by any integration:
That’s great! Thanks! However, are you sure the condition in the automation works properly?
I copied paste, by removing the ikea test and it also go through the condition even though the macro does not return anythin…
The condition I typed in:
{% for state in states.sensor -%}
{%- if "linkquality" in state.name and (state.attributes.linkquality < 15 or (as_timestamp(now()) - as_timestamp(state.last_updated) > (12 * 60 * 60) )) -%}
X
{%- endif -%}
{%- endif -%}
{%- endfor %}
{%- endmacro -%}
{%- if GetDroppedZigbee()[0] == "X" -%}
true
{%- else -%}
false
{%- endif -%}
Have you tried it in the dev tools and see what the outcome is? Try testing it there
For me it works flawlessly.
@Skye Hey I was doing some reworking on my automations and cards due to changes in zigbee2mqtt and thought will affect your great atomation. Arent they ? and pottentially if @mgi has new setup {%- if “linkquality” in state.name -%}`
This will always return false…
Also I am not that skilled but from now on this shold check if entity has attribute linquality?
The auto-entities syntax of the original answer doesn’t seem to work anymore. This auto-entities filter shows the link quality of all entities which have a linkquality attribute, that is null or above 0:
filter:
include:
- attributes:
linkquality: null
options:
type: attribute
attribute: linkquality
secondary_info: last-updated
sort:
method: name
- attributes:
linkquality: '>= 0'
options:
type: attribute
suffix: LQI
sort:
method: attribute
numeric: true
Here is a whole card I use on HAOS to keep track of the system health. It integrates the filter above in a dropdown menu, so that the card is not showing all the entities by default and keeping things tidy:
type: vertical-stack
cards:
- type: custom:battery-state-card
title: Batteries
secondary_info: last_updated
sort_by_level: asc
collapse: 3
filter:
include:
- name: attributes.device_class
value: battery
- type: entities
title: Updates
entities:
- entity: sensor.hacs
- type: custom:auto-entities
card:
type: custom:fold-entity-row
head:
type: section
label: Supervisor Add-Ons
filter:
include:
- domain: update
sort:
method: name
card:
head:
type: section
label: Zigbee OTA Devices
filter:
include:
- attributes:
device_class: update
sort:
method: name
- type: entities
title: Zigbee Entities
entities:
card:
head:
type: section
label: Sort by Link Quality
filter:
include:
- attributes:
linkquality: null
options:
type: attribute
sort:
method: name
- attributes:
linkquality: '>= 0'
options:
type: attribute
suffix: LQI
sort:
method: attribute
numeric: true
card:
head:
type: section
label: Sort by Last Seen
filter:
include:
- attributes:
linkquality: null
options:
type: attribute
- attributes:
linkquality: '> 0'
options:
type: attribute
suffix: LQI
sort:
reverse: false
card:
type: entities
title: Unavailable Entities
filter:
include:
- state: unavailable
sort:
method: name
show_empty: false
For this to work you need to install these plugins from HACS:
- auto-entities
- fold-entity-row
- battery-state-card
