There are different picutre cards available by default in HomeAssistant.
All of them requires a static path to an Image - none allows to setup an entity that provides the image path…
example:
Using the following code in the template area
image: {{ states('sensor.....235_model_image_url_large') }}
I am getting the path of the image as output:
image: https://.....Ww-C-1080570dayvext_front1080.png
But the only way on how to use the picture in one of the picture cards is to copy the URL and paste it in the configurator?
I can’t use this in the same way:
type: picture
image: {{ states('sensor.tmbjb7ny4nf047235_model_image_url_large') }}
tap_action:
action: none
hold_action:
action: none
It would be great, if the picture elements could be updated to support entities that provides an image path.
