As the line says, all Tuya motion sensors keep reporting “Detected” forever and do not go idle. Hope you guys can fix this.
Hi, I’m also having this issue and haven’t found any information regarding this.
I got some new Tuya sensors and they all show “Detected” permanently (I’ve even put them in drawers to make sure they were not detecting anything).
If anyone know how to fix this, I’d be very grateful!
Most motion detectors are configurable for reporting ‘off’ again. By default this report is not enabled. Dont know for tuya, but you should be looking for device settings around this motion off reporting.
@checking12 unfortunately, this seems to be an issue with “cheaper” PIR sensors.
@Ghost_Buster I was able to work around this using the solution posted here:
opened 07:38PM - 28 Oct 21 UTC
integration: tuya
### The problem
Hello hard working devs and testers,
I installed Home Assist… ant 2021.11.0b0 today, and specially for the Tuya integration.
I deleted V2 and started over with the build in integration. And i must say, **AWESOME**.
But, there is always a but :-) the PIR sensors doesn’t update. It doesn’t release detected status. The door sensors works as it should.
Next test: Tuya Water Cooker 😀
### What version of Home Assistant Core has the issue?
Home Assistant 2021.11.0b0
### What was the last working version of Home Assistant Core?
_No response_
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
Tuya
### Link to integration documentation on our website
_No response_
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
_No response_
### Additional information
_No response_
Hope that helps!
Very cool! This should work for me. Same problem, but another state that i need to set in the script. Thanks!
