WTH - ZHA Visualization map
Visualisation map is cool option but if we have many devices it is completely unreadable. Therefore, I suggest that after selecting a given device, it shows only the routes for a given device. In addition, I suggest checkmark - show only best routes - to show only best route from each device to coordinator. You can also combine these two options - so if you select this option to show only best routes and then select one device it will show only one, best route, from this one device to coordinator.
The visualization map of Zigbee2MQTT is way better. I think ZHA should just replace its own map with (an adapted version of) the map from Z2M
Duplicate: WTH is the ZHA network map looking so messy and is not usable?
This is a good idea. Add it to that thread
